Tempstar high pressure switch location
Hello- Can someone tell me where the high pressure switch is in the Tempstar Smartcomfort furnace? Thanks.
Last edited by hvactechfw; 04-16-11 at 08:51 PM. Reason: do not hijack another thread, it can become confusing on which problem you are talking about between different poster's
um, well there is a pressure switch and a high temp switch called the limit switch, but not a high pressure switch in furnace. pressure switch is a black or silver circle with two wires and the limit is inside the furnace right above the burners.
