heat won't come on
On our central ac/heat system, the heat won't come on unless you turn it on manually. If you set the thermostat and leave it on auto, the heat never comes on. We replaced the thermostat and it still doesn't come on. The AC works just fine. It's just the heat. Any suggestions?
Type of heating system? Central is alittle vague. Gas, heat pump, oil, etc.
heat won't come on
It's an electric central heat/air system. I don't remember the brand. It's not a heat pump.
Sounds as though your heating timer relay has gone bad. In heating the fan circuit is timed, to give the electric heaters time to warm up before the fan comes on. If your unfamiliar with electricity and schemetics, please call a tech.
Previous Thread
Next Thread
