Checking Freon Charge/Pressures on Heat Pump
Old 12-30-00, 06:49 PM
Guest
Post
A home heat pump appears to be low on Freon. Would like to check operating pressures using a set of std.manifold gauges. I understand that there are three ports on a heat pump rather than two as on an A/C only unit. Could someone tell me which two of the three ports need to be connected to the "High" and "Low" manifold gauge lines and how they can be identified?
Thanks
Old 12-30-00, 07:36 PM
fjrachel
Your suction line(bigger one) is high pressure. I hope you are EPA approved to handle freon. If not, call a tech, big fine if you get caught without it.
