weather maker 8000 furnace by carrier
Old 05-02-11, 02:13 PM
it goes through all the cycles but the blower motor will not kick on any solutions
Last edited by hvactechfw; 05-02-11 at 06:13 PM. Reason: moved from another thread, please do not hijack threads.
Old 05-03-11, 05:57 AM
Jay11J's Avatar
Sounds like the motor or board may be an issue.
What happens when you set the t-sat fan switch to "ON"?
Old 03-07-13, 10:32 AM
T
I just had this happen to me. I took the circuit board out and quickly discovered the 120 volt input on the main relay to the fan was fried. I cleaned up the carbon from the arching and re-soldered it. The trace on the circuit board was burnt away a little but I was able to bridge it. The other option would have been to add a wire from the relay to the power input connection (labled L1). Hope this helps someone else.
