Gas heat: Running fan without heat issue
Old 12-31-00, 09:10 AM
Angry
My gas heater of the house experiences the issue of running fan without heat. Re-setting it brings the heat back with burning smell, and it runs again. It happens in the following situations:
1. Cold days
2. While re-setting the temperature settings.
This problem has been lasting for at least 2 years. Technicians came to repair and could not find the causes. Does this issue have something to do with the furnace system? Or something else? Thanks.
Wei-Ching
Old 12-31-00, 10:33 AM
fjrachel
Where the technicians dealers of the brand furnace you have? If not call a company that deals in your equipment. It seems as though your going out on a limit switch. Have you replaced your filters?
Old 12-31-00, 04:18 PM
1. My furnace brand is Heil.
2. Air filters to the heater and conditioner have been replaced.
3. But not the filter to the furnace. Is there a filter for every furnace? Is it possible to have a blockage of the filter to the furnace or a blockage of the flue gas? Thanks.
Wei-Ching
Old 12-31-00, 04:40 PM
fjrachel
Call Heil HVAC company to check it out.
