York Diamond 80, blower working intermittently
Old 05-21-11, 08:54 AM
W
I have the same issue that I saw in the below link.
Need to find out where to pick up the motor. It says a GE 5kcp39ggN664BS 1/3 HP, 1075 rpm. But the frame that is attached needs to mount in the cage for the squirrel fan. The mount frame is three brackets with a rubber washer in it. Any ideas where to find a motor?
Motor is bad, I have voltage from the board, replaced the cap and it cuts out after about 10 minutes and than will start again after it cools down for 5 minutes.
The below link also describes the same problem.
http://www.doityourself.com/forum/ga...mittently.html
Old 05-21-11, 01:01 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
go to a electrical/motor shop. They can get you a motor and a belly band mount.
Old 05-22-11, 09:28 AM
G
Received 2 Upvotes on 2 Posts
An electric motor shop is your best bet, but if you live in an area without one, check the thread below.
Search GE 5kcp39ggN664BS 1/3 HP, 1075 rpm - Grainger Industrial Supply
