gas hot water heater
Old 01-01-01, 02:12 PM
Guest
Hot water heater does notr seem to be heating the watr as well as it once did. Heat setting is at the hottest. Also is doing a lot of hissing noises. Does it need replaced it is 9 years old, builders grade. If so I am handy with tools is it difficult to replace?
Old 01-01-01, 02:21 PM
It might be better if you post this in the Plumbing Forum.
Old 01-02-01, 05:29 PM
PDF
2 BIGGIES
HOW DO THE FLAMES LOOK IN YOUR HEATER?NICE AND BRIGHT AND BLUE?WHEN WAS THE LAST TIME THEY WERE REMOVE AND CLEANED?IF YOU HAVE A COUPLE INCHES OF SEDIMENT IN THE BOTTOM YOUR UNIT , THE HEAT TRANSFER WILL BE BAD.WHEN WAS THE LAST TIME YOU DRAINED AND FLUSHED IT R E A L G O O D????????PDF
