heater question
Old 01-03-01, 08:49 PM
Guest
Okay, I've this analog thermostat on my AbleAir
Furnace. I tried moving the copper bar to the lower
numbers. I presume this number represents the interval
that the sensor checks whether it should keep running
or stop. Anyways, I found out that I have this problem
in that the bedrooms get warmer sooner since ther are
smaller and closed, whereas the room where the thermostat
is (dining room) doesn't reach that temperature as quickly.
I have found cases where the fan runs even though I've
the heater on. How is this thing supposed to work
when the temperatures of different rooms vary?
Thanks for any clues!
Old 01-04-01, 02:27 AM
some help
Hello
you need to balance the system..best to use dampers in the heating duct but you can use adjustable heat registers. open up the heat into larger room and close down the heat in smaller rooms. also if the door is closed to the bedroom you should have at least 3/4" to 1" under the door so the heat can be pulled out back into the cold air return...
