goodman 125-4
Old 07-31-11, 11:22 AM
B
goodman 125-4
Last week my circuit board got wet and I believe it shorted out. The board lights and powers up but the blower fan motor won't come on. Is there any way to bypass or jumper the fan motor to make sure that isn't the problem before I get anew board? The run capacitor seems to be fine and there is no smell of smoke from the motor, the main circuit breaker didn't blow and the squirrel cage moves freely?
Old 07-31-11, 11:42 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
wire L1 from door switch to black wire from blower motor.
Old 07-31-11, 11:55 AM
B
door switch black wire is on L2. Should I connect that to the black blower motor wire.
Old 07-31-11, 11:58 AM
hvactechfw's Avatar
Yes. Do that. ............................
Old 07-31-11, 12:58 PM
B
thanks a million it worked after I got up enough courage to try it
Old 07-31-11, 01:33 PM
B
Too bad your not in chicago or i would use you in the future or at least buy you a beer.
Old 07-31-11, 01:38 PM
hvactechfw's Avatar
pay it forward..... If you good at something help out here.
