Goodman GSM flashing light
Old 09-15-11, 08:36 AM
D
Turned on my 12 year old Goodman GSM furnace for the first time this season and the red light on the HSI module is flashing continuously, does not go into ignition or purge mode nor does the combustion blower start, but 5 seconds later the furnace blower starts and runs, no heat . Troubleshoot code says Twinning-Check Polarity. Not using TWIN term, unit is standalone. 115 power to board ok with correct polarity, HSI fuse good, draft inducer/purge motor turns manually-not forzen. Recent work was new gas valve last year. Other than that unit has been trouble free. Grateful for any help.
Thank You, Dave
Old 09-15-11, 02:32 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
Check you ignitor............
Old 09-16-11, 12:52 PM
D
Update Goodman Flashing Light
The Main Module was defective. I painstakingly checked ever component, limit switches, purge motor, coils, gas valve..... everything but the flame sensor. Since it never got to ignition I figured the flame sensor wouldn't cause a continuous flashing light. SO by elimination it had to be the module. Got it the next day from an online vendor. Best price out there and free shipping overnight. Hardest part installing new wiring loom that came with upgraded board.
Thanks to those who replied..Dave
Last edited by hvactechfw; 09-16-11 at 03:46 PM. Reason: removed advertisement for website
