Rudd Achiever 90 plus
Old 09-15-11, 04:38 PM
N
I have a Rudd Achiever 90 plus. When I try and turn it in the two green lights come on ,But the yellow won't come on and the furnace won't start and kick heat. I don't know if its the ignition switch or the flame sensor, how can i tell whats wrong?
Old 09-15-11, 05:07 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
cleaning the flame sensor is yearly maintenance that should be done anyway. you need to take the burner door off and list out the sequence of events that happen for us to give you much help.
Old 09-16-11, 09:20 AM
N
The only thing I can say is I push the ignition button and it sounds like its running but no flame or the pilot light won't start and it won't deliver heat...
Old 09-16-11, 10:21 AM
hvactechfw's Avatar
What ignition button?..................
