water leaking on the return air duct of central heating & cooling system
Old 09-25-11, 08:16 AM
Water leaks even after I turn off the furnace and AC on the return air duct. The water comes out of the duct cleaning hole. I also turned off the water pipe to the humidifier attached to the furnace. There seems no water source that goes into the air duct. I just could not figure out why.
Old 09-25-11, 02:17 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
The ac drain is probably clogged. The water is condensation from the evaporator coil.
You may be able to clear the drain from a tee in the primary drainline.
Old 09-26-11, 10:00 AM
Great tips. I will give it a try. Thank you very much.
