Infinity Weather Maker Gas Furnace trouble
Old 09-26-11, 09:23 AM
G
I have an Infinity Weather Maker Gas Furnace with Automatic Ignition. Few days ago I had to shut power and gas off to install new gas line for stove. When I started the system up the emergency heat indicator light comes on and blowers start up. There are no reset switches and was wondering what I could do before I have to have a service guy show up. Model # 58MVP060-14
Old 09-26-11, 10:12 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Possibly air in the gas line. It may take sevearl relight trys before it ignites.
Odd, it should have thrown a code failure to ignite.
It code of course be something else but I would try firing it up a couple times.
It should light. Let us know.
Mike NJ
Old 09-26-11, 02:49 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Is your stat set for emergency heat or heat? Turn system off and back on and try again.
Old 09-26-11, 06:24 PM
Jay11J's Avatar
I've seen this happen to my in-laws, for odd reason the stat showed this (No heat pump)... I went into set up menu, and nothing was changed... I went back to the main screen and the Em heat was gone.. ??
Old 09-26-11, 07:38 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Flipping the "light" switch next to the furnace off and back on again should reset the lockout and give you 3 more attempts to start.
As lawrosa has posted it may take sevearl relight trys before it ignites.
Carrier now requires you to remove the outer panel to see the diagnostic light.
They had it right the first time, I wish they would correct this.
Do you have the Infinity stat connected to this furnace?
