How do I get inside a Dependable Ninety-Two?
Old 09-28-11, 11:55 AM
B
I have a chipmunk that got inside the heater. I can smell it in the basement but not in the heating vents upstairs. Smells like burned hair around the furnace. I can't find a serial number on the outside. I'm guessing it must be on the inside. I can't figure out how to take off the front. There are 2 some-kinda black fasteners at the top, but they seem like they must have to be broken to remove? I'm lost.
Thank you for any help you can give me.
Old 09-28-11, 04:27 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
you need to turn the tabs 90 degrees and the should release, if not, then break them and put sheet metal screw in the top to hold it in place. This is often times how I find that furnace when I walk up to them (with screws holding the door on).
Old 09-28-11, 04:32 PM
B
Thank you, I'll give it a try!
