Installing a above groung fuel oil tank
Old 09-28-11, 01:29 PM
R
Hi friends,
I'm currently switching to a above ground tank after my underground tank has failed. I understand the vent and fill has to be accesible to the outside, but there are two fuel lines coming out of the oil burner. Where do I install the return line in the tank? Or do I not need a return line anymore? Thank you for your time.
Old 09-28-11, 08:58 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
I suggest a single line off the top of the tank & a Tigerloop. Tigerloop
To convert to a single line you will have to remove the by-pass plug from the pump on the burner. Be sure to install a drain valve in the tank & pitch the tank toward the drain valve.
