Beckett burner motor#2456
Old 10-01-11, 08:28 AM
Dear Sirs,
I have a Beckett AFG burner that is 20 yrs. old and beginning to give a problem. The burner gets stuck once in a while and unless I physically spin the fan, the burner will not fire. I assume it is the motor with a dead spot because once I spin it, it runs fine. Where do I find a motor to fit that burner and what #s do I use to place an order? The instruction booklet is telling me the Beckett part # is 2456. How do I order??? Thanks, JoeA
Old 10-01-11, 04:42 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Here is a direct replacement: Patriot Supply -
This motor is a split capacitor type & the current motor used by Beckett on the AFG burner. Yours is likely physically larger due to it's being a split phase type. No manufacturer still uses split phase motors, only split capacitor type.
Old 10-02-11, 07:09 AM
Beckett motor
Many thanks Grady,
Not only are you helpful but also educational. Thanks again. JoeA
