Older Whirlpool Gas Furnace Won't Come On
Old 10-02-11, 09:35 AM
P
My furnace gas won't come on.
It is a Whirlpool FSB74-125B
The pilot is lit.
Blower will run
The transformer has 120 Volts at each terminal.
Old 10-02-11, 09:59 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check your 24V transformer.
Old 10-02-11, 10:11 AM
P
The wires at the thermostat also have 120 V. Is this a good indication that the transformer is bad?
If so are these model specific, or is there a generic one I can get?
Old 10-02-11, 10:55 AM
hvactechfw's Avatar
Is it for sure a 120 to 24V transformer? if so, I would say yes bad transformer, but I would also say be ready to replace more components....If they were delivered 120V instead of 24V then they might be fried as well.
Old 10-02-11, 11:01 AM
P
yes its a 125 to 24.
The gas valve had 120 volts at the terminals. do you know if thats correct?
Old 10-02-11, 11:08 AM
hvactechfw's Avatar
no, typically not correct.... you probably need a new transformer, stat, gas valve, and possibly a relay.... but hard to say until you replace the transformer.
