Rumbling from furnace
My furnace (25 yr oil burner) has started rumbling when it starts up. Sometimes the vibrations are pretty bad, sometimes not. I just had it serviced (new nozzle, new filter, cleaned) about a month ago. I do know the ignition transformer is weak. Any ideas as to what might be going on and what I can do to fix it? Also, I am looking at replacing this beast this summer. What are some thoughts about the duel fuel furnaces (oil/wood)? Thanks.
Pat Russell
Pat Russell
Thanks, I thought that was the problem but the transformer is about $250.00 so I wanted to get some other opinions first. That price is what the repairman gave me so I will look for a cheaper one. Thanks again.
Pat Russell
Pat Russell
Go online
Go online for the hell of it.Somewhere you can pick up info on wholesale prices for what you need.250 bucks.WOW!!!!I have read a lot of responses on this forum.It is certain companies or people that leave a bad taste in our customers mouths.PDF
What it sounds like to me is that something is not set up
right on your oil burner. Have the ignition transformer changed($65.00 sounds right). Have the serviceman check the porcelins for cracks, set the ignitors correctly, make
sure the unit does not have too much combustion air(which
can make it start hard), nozzle is correct for the unit, and have the pump pressure checked. When he is done, have
him set the unit up with combustion test instruments. If
you call the service company and explain that it hasn't been running correctly since it was cleaned, you may just
have to pay for parts. GOOD LUCK!!
