Thermo Pride Oil furance
Old 10-15-11, 11:28 AM
Y
Unhappy Thermo Pride Oil furance
Hi:
Does anyone know how the 24 Volt wire hook up to the Thermo Pride furance?
I had the insulation done this summer, when it is time to turn on the furance, it does not work, no sign of any power. I went to the crawl space to check on the furance, saw 2 loose wires. There are 4 terminal post nearby, 2 post have a heavier yellow color wires and each mark as "S", it seem to go into the motor or the furance. One of the loose wire which is white seemed to connect to the 2nd "S" terminal, the other 2 terminals are marked "T", There are one wire connected to each terminal and I think it goes up to the thermostat control. The 2 loose wires seem to go to a 24 volt supply. The white loose wire seem to go to the 2nd "S' terminal, but I am not sure which terminal the other red wire is connected to. Does anybody know?
Thanks
Old 10-16-11, 06:10 AM
Jay11J's Avatar
Call the installing dealer back to get to check this out. They should of done a fire test, and most of all a smoke test.. Was this done before you signed off the job?
I am not sure what wires you are talking about for sure, and to play it safe, leave it be.
