Carrier Furnace 58DR100-HH
Old 10-21-11, 09:04 AM
Furnace blower motor stays on. Thermostat numerals not lit. Thermostat on off has no effect. Replaced thermostat, same problem. Replace circuit board, same problem. Jumped rest switch on the top, same problem. No heat, no fire and blower motor works. This unit has no A/C and was in place when I moved in in 1993
Old 10-21-11, 04:48 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Do you have 24va between R and C on the control board?
Old 10-21-11, 05:49 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
The fan running constantly is a symptom of a blown low voltage fuse on the circuit board. Check that.
If blown, the most common reason for that is thermostat wire cut by bein g caught in some sheet metal --- grounding the 24 VAC low voltage wiring which will blow the fuse.
Replacement 3 amp fuses can be obtained at auto parts stores.
Old 10-21-11, 06:56 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Your MANUAL
Looks like it may have a 2 amp fuse.
It could also be a blown fuse link.
Old 10-22-11, 07:45 AM
Thanks!! The wiring diagram is what I needed. The information is terrific. I replaced the board because the old style relays would stick. This will help me.
