Rheem Model# RCBA-3765GG17
Old 11-17-11, 04:53 PM
This is the # on the a-coil under the furnace--I'm trying to find out the btu rating of this Rheem Classic 90 Plus to see if it will work heating a 14x70 Mobile Home. I also need the condensate drain tray for the a-coil as it was missing from the package deal. Wonder if this piece can be purchased--Help Please
Old 11-17-11, 05:51 PM
Question
Are you saying you need the plastic drain tray for the evaporator? I'm guessing you have a gas furnace with the evaporator coil mounted under the furnace?
Old 11-17-11, 08:28 PM
Jarredsdad's Avatar
Drain pan part number is AE-59193-06.
Furnace rating should be inside of the furnace. You will have to tke the door off to see it. Or post the model and serial numbers and can look up.
