Wiring for 'Fan Only' for thermostat
Old 11-30-11, 12:18 PM
L
I have an Armstrong Ultra-80 oil furnace and a Honeywell programmable thermostat.
My oil bills killed me last winter so I put in a Natural Gas 30000 BTU Blue Flame heater that is doing a pretty good job heating my 1500 sqft house.
It might do a better job if I could use the fan on the Armstrong to circulate the air but the wiring from the thermostat to the furnace is only 2 wire.
Both my furnace and thermostat have YCGRW terminals and the the 2 wires are connected to the RW terminals.
Running a new cable is not a problem. Do I need to connect all 5 terminals on both the furnace and thermostat to control the fan?
If not, what needs to be wired? Thanks.
Old 11-30-11, 04:54 PM
F
Received 36 Votes on 28 Posts
To include the fan control with the heating only requires only that the G(reen) wire be connected at each end. I will state though that if you are going to pull in a new cable you might as well use a cable that has at least five conductors.
Old 11-30-11, 05:35 PM
L
Great, thanks. I will probably pull through some 4 pair Cat5 cable that I have and use that.
