furnace not switching on
I just moved into this house and the gas furnace does not always turn on when it should. I am not sure what model the furnace is but there is a Honeywell S8910U Universal Hot Surface Ignition Module manual next to the furnace. The furnace itself says Rheem on it, but I cannot find a model number. It has four wires going into it, R, W, G and C. R, W, and G are connected to the thermostat. I did have the C wire also connected, but the programmable thermostat manual said the C wire was optional so I disconnected it to see if that helped, but the problem remains. Here is the problem.
The thermostat is set at 70 and when the temp drops to 69 I hear a click coming from the furnace, and then a few seconds later the flame starts, then a minute later the fan starts, and then when the temperature hits 70 the furnace stops. When the furnace is not running the resistance between R and W is infinite. Then when the furnace starts the resistance between R and W drops to about 4 or 5 ohms. It remains there until the target temperature is reached and the furnace shuts off. My understanding is that this is normal.
But once every 24 or 48 hours, when the temperature drops it will drop well below 69 and the furnace does not come on, and I do not hear a click. The resistance between R and W is 5 ohms at such times, meaning the thermostat is working and the furnace should be on. But it isn't. If I then flip the circuit breaker open then shut, or if I turn the furnace off at the wall and then back on, or if I move the thermostat from "heat" to "off" and then back to "heat", in all three of those cases the furnace has then started right up like it should.
I had a repairman out to look at it and it was working fine when he was here, and he suggested to me that the problem was probably the batteries in the thermostat. Last month (before I moved in - I am renting from a person who just bought the house), this repairman had put in a new igniter for the new owner. The owner also removed the old thermostat but I do not know why. The current thermostat is a Filtrete 3M-22 that was still in the box when I got here so I hooked it up myself with help from there 1-800 line. It was easy to do.
I don't know what the symptoms were that caused the owner to call the repairman in the first place or to replace the previous thermostat, and the owner is unreachable so I am trying to figure this out on my own for now. Any suggestions are welcome. Thanks
As you have discovered, a furnace doesn't just "turn on." It goes through a sequence of events and produces heat if it completes that sequence.
You've now observed and described that sequence when the furnace is operating normally. You need to observe the sequence when it fails to operate properly, and describe the sequence of events that occurs then and how far it gets in that sequence before not proceeding further.
You can also describe any patterns to the failure to produce heat.
Frankly, the smart thing is to call the landlord and require him to complete repairs to the furnace. Getting in between the repairman and the landlord is likely to be a mistake.
But it's up to you.
But it's up to you.
thank you for your reply and help. What you suggest is exactly what I tried to do in paragraph three of my post, which describes the sequence of events that happens when it fails. The thermostat causes the r/w connection to go from open to short, and nothing further happens until I flip the furnace on/off switch, or the circuit breaker, or switch the thermostat from heat to off and back to heat.
The landlord is out of the country and not returning my emails. My cell phone does not call out of the country. This weekend I plan to use a pay phone to call out of the country, assuming I can find one that does.
