furnace blower electrical motor
Old 01-04-12, 08:07 AM
T
Greetings! I have a Armstrong Ultra sx 90 furnace and the blower electric motor started few weeks ago to make a noise when running.
I suspect that might be the bearings.
Is it anything that I can do by myself to fix this?
The motor is in a cage (might be dust proof) with a lot of wires in/out and removing it by myself I don't think is an option.
Can these bearings be greased or lubricated somehow without removing the motor or do I have to call a specialist?
You know, it is after the holidays and I don't have to much money left...
Old 01-04-12, 09:39 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Very few blower motors use grease. Most have two oil ports that need to be oiled every few years. Some are permanently lubricated and have no oil ports.
If it's a motor that needs to be oiled, usually one of the oil ports are visible at the end of the motor.
If that's what you have, sounds like you'd better have a repairman do the job for you. Oiling the one visible oil port is a waste of time, and to do both requires completely disassembling the fan assembly to get at the other oil port ---typically that takes 45-60 minutes or so.
And don't put it off. A motor that has started to be noisy because of neglected oiling will be a seized up motor that needs to be replaced in a few days or a few weeks. Get it oiled now and save yourself the expense of a new motor.
Old 01-04-12, 09:45 AM
T
thank you,
I don't remember to see a lubrication port, but I'll look again in the afternoon.
To disassemble the motor I don't know if it's a good option now, in the middle of the winter, I'm not an electrician and I hope I can go another few months with this one...
