Strange whistle noise
Old 01-08-12, 01:24 PM
D
I have a 10 years old Bryant gas furnace, model #383KAV. It will develop a high pitch decreasing whistle, like a rocket, in it's sequencing process. I kind of wait for the explosion before it quits. Am I having a problem some place?
It appears to be working fine except for the sound affects.
Thanks
Old 01-08-12, 01:33 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
You need to pay attention and track down where the noise is coming from --- and when.
Describe the sequence of events that takes place when you turbn the themostat up and include in that a description of whn this noise occurs and where it comes from.
Old 01-08-12, 02:02 PM
D
It is prior to ignition. Cannot tell exactly where it is coming from except it is under the cover where the burners are at. It does not sound like a axle/wheel needing lube. It is a harmonic sound. I do appreciate your help. Bob
Old 01-08-12, 04:07 PM
Since you aren't able to follow the directions --- better call a pro to help you.
