Gas Furnace
Old 01-09-12, 12:12 PM
U
Gas Furnace
I have a natural gas furnace in the summer running air it started to leak if I ran the fan on low it would not leak a friend said the A Coil needed cleaned. I call a furnace place to see how much 500.00 because they would have to take off the coil and remove lines refill the freeon.
I just have no clue so just asking if this is normal to have to do all
that that furnace is bout 10 years old air unit 8 Thank you for any help
Old 01-09-12, 03:10 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
need pictures of the setup to see if that would be necessary, but yes sometimes it is.
