Lennox gas furnace problems
Old 01-14-12, 04:23 AM
B
Help I have a lennox G24m furnace and the unit comes on and runs for 20 sec and the blower will not come on. Before igniting LED #1 flashes slowly while LED #2 is on. When the furnace has ignited both LED's flash fast. Any idea what the problem may be?
Old 01-14-12, 07:01 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
look on the blower door (both sides) or even the burner door for a legend that describes what the LED flashes mean.
Old 01-14-12, 08:11 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Also, describe in detail and in sequence what happens when the thermostat is turned up. " the unit comes on and runs for 20 sec " is too vague to be of any help.
Old 01-14-12, 08:19 AM
B
Thanx for your assistance, I've figured out the problem. BTW, it seems crazy that it takes 4 clicks to get to my posts. Is there a shortcut from the homepage?
Old 01-14-12, 08:38 AM
B
What was the problem?
Depending on your browser, you can usually drag the url address from the top of the browser window onto your favorites bar to make it a favorite. Then you can just click on that for next time.
Old 01-14-12, 08:42 AM
hvactechfw's Avatar
you should be receiving an email with a direct link every time there is a post on your thread unless you have your settings setup to not do that.
