York Diamond 90 no call for heat
Old 01-19-12, 08:30 AM
I have a York Diamond 90, about 17 years old.
Problem I am having is: Heater will come on and bring the house to temp, then I see a continuous flashing LED (no call for hear) and the blower will remain on forever . If I increase the temp setting the heater will again light and bring up to temp. Blower again will remain on with flashing led (no call for heat)
Old 01-19-12, 09:47 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
I'd start by using a multimeter to check for 24 VAC at the R and W terminals on the furnace. The R terminal should have voltage all the time, and the W terminal will have voltage when the thermostat is calling for heat.
Find out if the thermostat is indeed calling for heat when it's turned up.
Old 01-19-12, 07:59 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
a slow flash may be normal for no call for heat. You may have your thermostat set to Fan ON instead of AUTO.
