Furnace shuts off - help??!!!
Hi there - we have been having a very intermittant problem with our gas furnace - it shuts off completely on it's own - if we go down to the furnace and turn the power switch off and on again it will restart no problem. This sometimes occurs 6 times in a day and then will go 2 weeks or more without acting up and then happen once and then not again for 4 days. We have replaced the thermostat several times - still occuring. Any ideas? Thanks a million! Gil
By cycling the power you are resetting the control board and clearing any faults. While the furnace is acting up you need to look through the window in the blower door for a diagnostic Led flash code.
