Furnace issues
Old 02-06-12, 12:30 PM
Furnace issues
My furnace runs constantly without producing any heat. I replaced my thermostat with no luck. Furnace is a Carrier 58GS050-AA. Any suggestions will be appreciated.
Old 02-06-12, 03:49 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Many furnaces have a small "window" in the blower door thru which you can view a, usually blinking, light on the control board. If yours has such a window & you can see the blinking light, count the blinks the remove the door. On the inside of the door is often a sticker which decodes the blinks.
Old 02-06-12, 03:54 PM
Re: Furnace issues
Grady, thanks for the rapid response! I believe the furnace is the original furnace that came with the house (1989), and does not appear to have any "electronics".
Old 02-06-12, 03:58 PM
Grady's Avatar
If the furnace has not been serviced in the past couple of years, you need to contact a local service company & have it done. Oil burners should be serviced annually or no less frequently than every other year. BTW, Honeywell makes only controls, not furnaces.
