Inter-City Products Corp Gas Fired Forced Air Furnance False Starts
Old 02-06-12, 04:00 PM
Hi - I have a Inter-City Products Corp Gas Fired Forced Air Furnace - Model GNJ050N12C1 - 50,000 BTU/hr.
The thermostat is set at 65 deg F and when it is warmer in the house - just from the sun heating up the house - the unit goes thru a starting cycle by kicking on the inducer fan, but never goes any further, it just shuts off. It continues doing this false start sequence continuously. There should be no call for heat at this point, so I do not know why it falsely starts. I tried shutting the power off and restarting it, but it still goes thru this false start sequence. If I then turn up the heat so I am calling for heat, then the furnance will start normally. any ideas here? Or any trouble shooting ideas?
Thank You.
Old 02-20-13, 08:20 PM
Well, I got the answer to my problem - I ended up swapping out the electronic thermostat and the system operates as it should. I think I killed the original electronic thermostat by using rechargeable batteries. It turns out that the rechargeable batteries operate at a lower voltage than a store bought alkaline type. This must have screwed up my honeywell digital programmable. Since I swapped out with a new programmable unit the system works fine! No more false starts, no more condensation coming back thru the flue liner, and the best part, my gas bill was reduced significantly! So the moral of the story is DO NOT USE RECHARGEABLE BATTERIES IN YOUR THERMOSTAT! I actually found from an online search that the rechargeable batteries should be limited to use in certain items only! I hope this may help some other poor soul someday! Regards.
Old 02-21-13, 05:21 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Glad you found the solution to your problem & THANK YOU for passing along your tough lesson experience. It may indeed save someone else from the same fate.
