furnace is making a loud vibration sound
Old 01-16-01, 05:11 AM
Guest
When the furnace come on, it makes a very loud vibrating noise. It sounds similar to a washing machine that is off balance. This is a natural gas, forced air furnace and it is four years old. Can anyone give me some advice on how I might correct the problem myself? Thanks!
Old 01-16-01, 06:42 AM
R-12guy
Check the Blower, a mouse could of gotten in there...or the blower wheel might be loose... maybe even bearings going up...
Old 01-16-01, 02:49 PM
PDF
Sounds like belt drive
I would say your belt is past its time and needs to be replaced.PDF>>>>>JUST HOPE IT IS not the squirrel cage or bearings.If it is a sleeve bearing motor.it will mean a new motor.PDF
