Keeprite DC90 Furnace not giving heat!
I turned the furnace back on the other day after a couple of weeks and now it will only blow cool air. I turned it off on the thermostat but it kept running, so I cut the power. Looked for a reset button/switch but couldn't see it. Suggestions?
Take the cover off the burner compartment of the furnace. Obtain the make and model of the furnace off the rating plate in the burner compartment and post it here.
Observe the sequence of events that occurs at the furnace when you turn up the thermostat and post that sequence of events in order and in detail.
