Carrier 58MSA - Error code 31 - blower starts but main blower never does
Old 04-13-12, 08:50 AM
K
I'm calling for heat. light is steady on. the blower starts and runs for about 30 seconds before it generates an error code 31. The main blower never comes on. I have assured all vents are clear. It all looks clean and sounds good. No evidence of leaking water. Any suggestions?
Old 04-13-12, 02:39 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check voltage to the blower motor.
Old 04-14-12, 01:01 AM
user 10's Avatar
Received 53 Upvotes on 47 Posts
Code 31 on your model indicates that the pressure switch isn't closing.
The pressure switch makes sure that there's a proper draft (created by the inducer/venter motor) prior to ignition.
Check the exhaust and intake pipes for a blockage where they exit the house.
Make sure that the condensate drain isn't blocked.
With the venter motor running, wave your hand over the end of the exhaust pipe - there should be air movement.
Other problems can cause the pressure switch not to close; call a technician if it's not something obvious.
Old 04-14-12, 07:37 AM
K
Blower voltage 225vac
Yes, the trap is clear, and there is free airflow in and out of the venter blower. I checked the blower voltage and it is 225vac. It seems/sounds pretty normal with strong airflow. It just comes on and after about 20-30 seconds the light starts blinking the 31 code... is it time to call in a pro? I'd love to win this one
Old 04-14-12, 07:22 PM
user 10's Avatar
Is 225vac a type-o? Furnaces are normally 120 volts.
Check to see if the pressure switch is actually not closing. (with a meter)
You can also make sure that the tubes connected to the pressure switch are clear.
It's possible, but unlikely that the switch itself is bad.
If everything seems okay, call a pro.
A heat exchanger with popped crimp rings or large cracks can prevent the pressure switch from closing.
Old 04-17-12, 06:28 PM
K
Tubes must have been clogged
Sorry, that was a typo. The voltage is 125. I "tweaked" the tubes by pinching them and rolling them the full length. I tapped the pressure switch with a screw driver. It now works fine. How long it works is anybody's guess, but at least I know how to tackle it next time. Thanks for all the help, and saving me $.
