no heat downstairs
Hi,
My downstairs level is not getting any heat, while the upstairs is getting the amount of heat indicated on the thermostat downstairs. There is air blowing out of the downstairs vents, but it is cooled (as if it cooled on its way down). Is there anything that can be done besides buying a downstairs heating unit?
thanks in advance,
bluvw
thanks in advance,
bluvw
If the t'stat is downstairs, where your not getting any heat and the upstairs is at the correct set temp of the downstairs t'stat...Your question does not make much sense. If your setting is 70 and the t'stat is downstairs your heat should be 70 where the t'stat is. The t'stat is the control.
