Does oil continue to be pumped when burner switch is off,
Old 05-10-12, 05:14 AM
but thermostat is on? Thanks
Old 05-10-12, 08:49 AM
F
Received 39 Upvotes on 31 Posts
The oil pump is attached to the burner motor so if the burner is not running the oil pump is stopped.
There are, however, some fault conditions that could allow a small amount of oil to flow into the combustion chamber.
Old 05-10-12, 03:37 PM
re
Good to hear. Thank you for the reply. Thanks
Old 05-10-12, 03:47 PM
F
You're welcome. lofwemg[-ds0
