Tiger Loop full with oil
Old 08-27-12, 04:46 PM
I just noticed that my Tiger Loop is full with oil. The oil heater seems to be running fine otherwise.
Has anyone experienced a similar situation? If so, what might the cause be?
Thanks,
Scott
Old 08-28-12, 06:41 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
This is not highly unusal especially if the Tiger Loop is below the oil level in the tank. Usually a spring loaded check valve such as a Firomatic B-105 HCV (3/8') or B-205 HCV (1/2") ahead of the loop will do the trick. The best way is either get the loop above the oil level in the tank or install an oil safety valve. In each case the idea is to prevent either gravity flow or siphoning into the loop.
