American Standard Freedom 80 Comfort R - 3 Lights Error
Old 09-23-12, 01:28 PM
W
Hi,
I have an American Standard Freedom 80 2 Stage Upflow/Horizontal (Model #AUD100R9V5KO) furnace purchased in 2001 that has been working fine. This summer it stopped working once so I reset the circuit breaker and it continued working but I noticed a smell that reminded me of a burnt motherboard on a computer. When I turned on the heat yesterday it did not work. I checked the light on the board and when I first turn it on it blinks quickly for about 5 seconds and then goes into a 3 blink pattern. I can see a burn mark on the circuit board. Should I replace the circuit board or is there something else I should check?
Jim
Old 09-23-12, 01:31 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
with a call for heat does the inducer fan motor run (located below the burners)
Post a pciture of your burnt board.
Old 09-23-12, 02:40 PM
W
No, the inducer fan motor does not run. Here is a picture of the board:
Old 09-23-12, 03:20 PM
hvactechfw's Avatar
yep, time for a new board. The replacement part number is KIT15815 which includes an ignitor upgrade and small harness.
Old 09-23-12, 03:31 PM
W
Thanks for your help, I appreciate it.
