Need help! Forced air lennox furnace not kicking in.
Old 10-08-12, 09:24 AM
My furnace is not kicking in. When turned on it sounds like its trying to go then after a few minutes stops making any sound. Almost like its trying to get a motor going or something. I tried turning everything off and turning the gas line off for 5 minutes and restarting but the same thing is happening.
This is 6-7 year old lennox forced air furnace. Any ideas? Any suggestions?
Old 10-08-12, 05:09 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
post your model number
give a detailed description of the sequence of events that happen with a call for heat. Also check the diagnostics lights on the control board and the legend on the furnace that describes what the lights mean.
Old 10-08-12, 06:51 PM
G43UF
So when it calls for heat the unit has a sound go that sounds like "ehhhhhhhhhhhhhhhhhhh". This goes on for a while then it just completely stops.
The red light stays off, the green slow flashes. According to the diagnostic codes it indicates either:
A) Pressure switch open or
B) Blocked inlet/exhaust vent
C) Condensate line is blocked (for condensing furnaces only) or
D) Pressure switch closed prior to activation of combustion air inducer.
Old 10-09-12, 04:24 PM
I should note that the igniter doesn't glow.
Old 10-09-12, 05:29 PM
hvactechfw's Avatar
your inducer may be locked up or full of water. You need to find out what is making the noise.
