Need help with wiring diagram
Old 10-10-12, 06:21 AM
W
New guy here. I had my HVAC working fine and then I put a new control on it and now the fan stays on all the time. I have to turn off the 110 power to the HVAC unit for it to go off.
I have a Armstrong oil fired unit with a AC coil.
The control is a Honeywell Model R8184M1051.
I even turn off the unit at the thermostat and it still runs does not matter if I am using it for cooling or heating.
I am sure it is at the Honeywell unit since that is all I changed.
Thank you
Old 10-10-12, 08:12 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Disconnect all of the low voltage wiring from the control & let us know what happens.
