Honeywell CT87N Heating Question
Old 10-11-12, 08:54 AM
I
Cool Honeywell CT87N Heating Question
I tried searching old friends to find my answer, but wasn't able to find one after some research. The closest I have found so far is this: http://www.doityourself.com/forum/ga...t-problem.html
I am having the same issue where the T-Stat will only turn on if I have it set to about 7-8 degrees higher than what it actually states.
I have looked at the manual, I have the wire going into Rc and the jumper between R and Rc. Do I need to move my R wire to R (I don't think it should make a difference, should it)?
A/C works just fine, this is just with the Heat aspect.
Thank You
Old 10-11-12, 09:43 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Iggster,
I don't know why but I've had nothing but bad luck with this particular stat. I suspect it is the connection pins/socket. I've had to replace quite a few with a different stat.
Old 10-11-12, 09:47 AM
I
Any recommendations? I don't need anything fancy or flashy, just one that works.
Old 10-11-12, 10:00 AM
Grady's Avatar
My personal preference is White-Rodgers 1F78-144 but you are not likely to find it, or any White-Rodgers stat in a retail store. The Honeywell TH3110D1008 would probably do well for you.
Old 10-11-12, 10:06 AM
I
The company I work for has an account with Grainger, so I would be able to find the White-Rodgers w/out an issue.
I am still going to try and work on this one for a few days, and if I can't find a resolution then I will replace it.
Old 10-11-12, 06:01 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
What are the cycle rate dip switches set at?
1=?
2=?
Old 10-12-12, 05:31 AM
I
I will have to double check when I get back home, but I am certain I did not change them. So unless they came from the factory other than Off and Off that is where they should be. Yes I do have a gas heating system. Thank you for the detailed diagram.
Old 10-12-12, 06:51 AM
hvactechfw's Avatar
It is likely you need a new thermostat if this is a new problem on an existing t-stat.
