York Diamond 80%
Old 10-13-12, 01:57 PM
York Diamond 80%
The burner goes out and the blower just keeps running
Old 10-13-12, 08:31 PM
Received 25 Votes on 19 Posts
Please give a more detailed accounting of exactly what happens and when immediately after turning up the thermostat to initiate a call for heat. Include the timing of the induced draft fan (small blower) starting, the ignitor glowing, the gas valve opening and initiating main flame and how long the main flame is on before it is extinguished. This MAY be a simple fix.
Old 10-13-12, 08:44 PM
SeattlePioneer's Avatar
Just to repeat Furd's request with a bit more detail:
Take the cover off the burner compartment of the furnace. Obtain the model of the furnace off the rating plate in the burner compartment and post it here.
Observe the sequence of events that occurs at the furnace when you turn up the thermostat and post that sequence of events in order and in detail.
