pipe compound with teflon in it
Old 10-21-12, 08:12 AM
Yesterday I made some line repairs and installed another shutoff. I used pipe thread compound with teflon in it on some of those fittings. This morning I discover my fuel pump is shot (webster M34DJ-3). So my question is what does teflon do to fuel pumps and will it cause further damage if I just replace it without pulling those fittings. I have a beckett model AF-15 burning kerosine. Thanks
Old 10-21-12, 10:24 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
AFAIK pipe compound is correctly applied so that it can never get in the lines...just like tape. You start a few threads back so that when tightening it moves the stuff away from the flow path.
If you did that, then it was prob coincidence that the pump failed.
Old 10-21-12, 11:15 AM
F
Received 39 Upvotes on 31 Posts
Teflon is not the best joint compound for use with fuel oils. I prefer Permatex number 2 compound.
That stated, I agree with Gunguy that unless you had gobs of the Teflon on the threads the failure of your fuel pump was coincidental.
Old 10-21-12, 11:33 AM
michaelshortt's Avatar
Could the pump have lost its prime?
Old 10-21-12, 11:45 AM
Thanks guys and yor right. I just took it apart and found no sign of anything that should not be there. There is a round metal ring with a star shape in the middle that turns inside of another part that is binding up. Do you know if I can get parts to rebuild this unit? If so where can I find them. Thanks
Old 10-21-12, 11:53 AM
I did need to reprime after installing the shut off. It then ran normal untill this morning when it seized up. I Pulled it apart to discover the fuel pump was turning harder than it should.
Old 10-21-12, 12:03 PM
F
Those pumps are made to be used with #2 fuel oil. The kerosene you have been using does not have sufficient lubricating properties.
Old 10-21-12, 12:27 PM
Is there a replacement pump that would be suitable for both straight Kero and #2 as well as mixtures of both to replace this OEM pump? I live in northern Ny and the tank is outside.
Old 10-22-12, 07:09 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
I've had good luck with the Suntec A2VA-7116. Any pump used on straight kero will fail sooner than it would pumping #2 fuel oil but if it lasts 5 years or more, that's not bad.
