Goodman Gas/AC System - Flame Issue
My furnace runs. The issue I am having is with the flame coming on for a few seconds and then shutting down. I checked the 'Flame Sensor' and it looks good. While I had the sensor out, I did use steel wool and sand paper on it to make sure it was clean. Problem is still there. I do have a solid red light indicating there are no problems with the system. Has anyone run into this kind of problem before? Thanks for any help here.
Sorry I left out a piece of information as I am tired from staying up trying to figure out what could be wrong. The flame comes on, then it goes out. The flame comes back on and it goes out again. This happens over and over until the thermostat has reached the desired temperature.
Thanks...
Thanks...
