fraiser johnson household ges furnace?
Old 10-27-12, 11:41 AM
B
what is fault code 3 for this furnace?
Old 10-27-12, 04:48 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
need a model number of the furnace or control board to tell you that. Typically it is a pressure switch fault code. 95% of the time it is not the pressure switch that is at fault. Get the info needed and we can confirm what the fault code is.
