i am having problem with a bryant furnace.
Old 11-24-12, 03:44 PM
T
it was working fine and now it keeps short cycling
Old 11-24-12, 06:31 PM
Jay11J's Avatar
I moved you away from the thread you posted it on, You said you have a furnace, and the post was on a heat pump.
We need more info in your system, and t-stat control.
Is the burner shutting down right away??
Old 11-24-12, 07:26 PM
SeattlePioneer's Avatar
Take the cover off the burner compartment of the furnace. Obtain the model of the furnace off the rating plate in the burner compartment and post it here.
Observe the sequence of events that occurs at the furnace when you turn up the thermostat and post that sequence of events in order and in detail.
