Bleed valve for webster M34DJ-3 pump?
Old 11-29-12, 12:55 PM
C
Any idea which port / nut is the bleed valve? It doesn't have the zerk fitting like others I've seen.
Oil pump M34DJ-3... its a bit older. I know the "K" version now has the bleeder built in.
THANKS!
Old 12-19-12, 12:09 PM
P
If you're still looking, I received this diagram from Webster. The vent is at the top left side of the pump looking at the sticker.
