Miller Gas Furnace - M1BC066AB1, SerMiB990708077
Old 11-29-12, 03:24 PM
B
I am trying to find a service manual on the web but I get options for quotes and install replies, any idea where I can obtain this information?
I'm looking for spec's on the static pressure rating on the furnace - runs very loud.
Where is the fan temperature control located to adust the temperature seem to run alot. I'm in the HVAC field but have alway's worked on Miller oil furnaces.
Installation modular home ductwork in floor.
Thanks
Bob M
Old 11-29-12, 03:51 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Hi Bob,
I've moved your post out to it's own thread. You tacked it onto the end of another existing thread about a Weil-McLain boiler...
Also, I'm moving it again, because the forum you posted in is for Hot Water and Steam systems, not Hot Air...
Old 11-29-12, 04:02 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
I don't see any manual on line either.
You should find the static pressure on the rating plate for the equipment, usually found in the burner compartment. At least I'd look there first.
