Petro Miser Fuel Unit???
Old 11-29-12, 08:28 PM
I have a fuel oil pump which has locked up. This is an old coal furnace which has a fuel oil insert. It will be replaced, however I'd like to run it for a while longer to burn the remaining fuel oil before switching to propane. Anyway, any help in identifying this pump, finding part or finding a replacement pump would be appreciated. It is very hard to read the numbers on it. The front has "Petro Miser fuel unit". The numbers appear to read Sundstrand 5 LB 111 I have searched the internet for some time without finding much. Any "old timer" have any experience with this type of pump? Am I reading the numbers correctly. Thank you!
Old 12-03-12, 07:39 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Sorry for the delay in replying. Here's a link to Suntec with their contact information. They may be able to help you if you tell them none of the service people you've contacted have been able to cross this pump to a current model.
Contact Us
