Oil Furnace Brands
Can someone tell me what brands are good and ones I should stay way from?
Is lennox any good, I heard they were good long ago not sure how they are now (quality, repair costs, etc)
About the only really good old true design is ThermoPride. They are the tanks of the days furnace that are still made, not the lighter gauge heat exchanger that a lot of other brands are doing.
Received 40 Upvotes
Thermopride is excellent equipment. Hallmark (Williamson?) also has a heavy heat exchanger but it's not copper coated like the Thermopride. If I had oil fired forced air heat, I'd have a Thermopride... nuff said.
Received 40 Upvotes
I would stay away from Lennox or anything using the Beckett AF II burner.
Installation is far more important than furnace brand.
Regarding installation: DO NOT use a 2 pipe fuel system. To do so you are pumping fuel at the full capacity of the pump (aprox. 17 gal/hr) thus not allowing the filter to do the job it can with a single pipe where you are only pumping the amount of fuel you are burning. If the fuel line comes off the top of the tank, I suggest a Tiger Loop.
Received 40 Upvotes
i thought lennox was a good brand atleast from what i heard.
Read more: http://www.doityourself.com/forum/ga...#ixzz2G6Tt5Xlc
Lennox used to be really good stuff but now Lennox, Armstrong, & Ducane (maybe others as well) are all the same furnace with different controls & burner.
